Have you tried a throttle/TV cable bracket from a 260? They had two barrel carbs.
Out of curiosity, why are you using a 2bbl?
bill said:I havent looked at the 260 bracket yet. Im using the stock carb because thats what it came with and I may change that to a 4bbl eldebrock set up down the road. Now I see why its harder to stick with a 2bbl set up....nothing is made to fit it...lol.
dan2286 said:bill said:I havent looked at the 260 bracket yet. Im using the stock carb because thats what it came with and I may change that to a 4bbl eldebrock set up down the road. Now I see why its harder to stick with a 2bbl set up....nothing is made to fit it...lol.
Stay with a q jet if you ever switch to 4 bbl. So much easier and cheaper to find all the brackets and cables, plus you will need an adapter to mount an Edelbrock or Holley on stock or edelbrock intakes. There really isn't much to gain power wise either on an engine like yours, plus you will loose fuel economy.
G-Body_Vet said:Not enough adjustment in the brackets? What about a throttle cable from something that came with a dual jet? I'll cross reference that cable with something that would've come with the older 2GC carb. If it gives me the lengths it will tell the difference.
olds307 and 403 said:Why not get a late 70's 403 spec carb? They had improvements over the early carbs, flow more and easy to convert to electric choke. You will lose power and economy with that 2GC.
