That is a big cam if the heads weren't milled, as said do a compression test. If they were milled, it will be close to what you want for duration.
Yes I’m using the 200-4R built by Janis Transmissions with a 3000 stall. Right now I have a 650 QF but plan on running the Holley Sniper EFI.Old school cam, make sure you have enough stall. Using the 2004R? Of course it would need some upgrades.The stock D5 is rated at 2400 rpm. What carb are your running? The Street Demon 750 or modified 800 cfm Qjet would work great with that motor.
Yeah....I use to drag race an ‘84 Cutlass and it was Chevy powered. When I bought my ‘85 442 I promised myself that it would stay Oldsmobile powered. I just hope this motor is very streetable cause I drive mine a lot when the weather is nice. I long hauled it last year on the Power Tour with a stock 350.Good transmission builder and should be plenty of stall. That carb is small for that 350 but if going to the Sniper, just tune it for now. Talk to Cutlassefi before you go EFI. Nice to see someone pick an Olds 350, a really reliable under used motor.
