OLDS Olds 403 with new CAMSHAFT fitment?
Reactions: fleming442
Just curious, what country are you located. Also what happened to the 4A heads it probably came with?
when i got the engine it had the 5A heads on it . i also found a pair of 4A heads but i dont think that going from 5A to 4A make any difference for me !?Does it ?
The 4A heads flow better on the intake side but have huge 83+ CC chambers, mine measured 86cc and suck almost as bad as your 5A on the exhaust side.
No LS! The 4" stroker Olds 350 is a sweet package, much less reciprocating weight, strength and smaller journals for less bottom end failures than a 455. Definitely better low end torque than an LS and more than acceptable 400 to 500+ hp. I am building a 403 because I have the parts, stroked 330 crank included, mine is an auto and won't see past 5500 rpm. Hopefully it will live a long life.
It'll go 6000, just not often...
I often wonder how much my 468 bottom end will hold. I just can't afford to test it.
The 455 can rev but everything needs to be right. I just think a 350 with more stroke, along with billet and forged parts will rev along with major torque. There are many more 455 bottom end failures than the 350, I think parts weight and bearing size are the main reasons.
