Olds diesel performance
Turbolq4
1,732
4,207
Nampa Idaho
4bt Cummins swap. Far more reliable, more power.
Cummins has a crate 4 banger engine now. Comes with ecu but it's real money.
84dragcutlass
1,189
1,507
North Vernon IN
I'm putting head studs on mine, ARP. Should resolve the issue of the head gaskets blowing. For one of our cutlass we are using a 6.5 turbo diesel for obvious reasons but for my wifes cutlass we are building the original 5.7 olds diesel to see what we can get out of it
  • Friendly
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Why not! Please make a build thread. I think this would be awesome!
DoubleV
2,154
406
83
Medina Ohio
Keep us posted on the Olds diesel build.
Tuffregal83
640
1,150
Lockport, Il
My dad had one in a 81 Buick Electra Estate Wagon new never had any problems with it and he traded it in on a 84 gmc suburban as our family was growing 2 boys under age of 4 and one on the way at the time I remember picking up the suburban and my mom saying your brother or sister is coming we got to go to the hospital now so get it
I remember saying he or she will be there when we get there what's the rush
jlcustomz
983
1,096
I remember seeing & riding in vehicles with some way back when they were new. Seems the fuel delivery system was the biggest issue, at least at stock power levels.
Found the factory diesel computer under my el camino dash years ago. pretty tiny for an early 80's computer.
xxBLOOD88SHOTxx
142
164
Yeah its like 10k, its their "repower" engine or something like that.
A turbo LT6 could be interesting if it can do smokey burnouts and get 30mpg @ 80mph
Wageslave
1,750
3,342
Would there be another stronger gas engine that could be converted to a diesel, like they did to the Olds engines?
Imagine a 300 inline 6 Ford engine, headstudded with higher compression and a stouter rotating assembly. With a 6 cylinder injection pump driven off the crankshaft with a timing belt, and some Cummins or old IDI injectors. You could piece together a non-turbo diesel from readily available parts and a little machine work if you can find a block that would hold together under that kind of compression.
gnvair
1,102
1,307
The early diesels typically had a stand alone computer for the lock up controls on the transmission.
84dragcutlass
1,189
1,507
North Vernon IN
Those engines ship out of the cummins plant in Columbus I work at. Well put together little kit. Although yes it is expensive. It's a 2.8 liter that would move our cars around pretty well. Jeep guys use them mostly
