I would also take a grinder to those Thorton manifolds, supposedly far from ideal as cast at the port openings and exits.
So did I! LMAORead the title as Old guys, I might need new reading glasses.........
Well said, and agreed.The main use of 330 or early 350 heads is an easy compression boost on a stock 403 short block, same for a 350. Also the Procomp heads as cast are 83-84cc. Even with flat top pistons in a 350, 9 to 1 at best with tight quench. Procomp should offer the head as cast with a 70ish CC chamber and a blended port opening version with the larger chamber for the BBO. Honestly like Edelbrock offers for Pontiac, there should be a 67cc chamber option as well, we are not a big enough market unfortunately. I don't know if Olds Rocket Parts is going off the 77cc spec and doing a .060" cut, thinking so as their 69cc head actually measure 73cc I believe. That will give 10 to 1 with KB pistons. The Edelbrock head is definitely superior as cast with 265 CFM intake, arguably a better chamber shape and with much better parts but double the cost and still only one chamber option. With the .060" head mill, your intake will definitely need cut, another good reason for a smaller as cast chamber, nothing is bolt on like the chebby world, SBO stuff especially.
