Olds V8 squeaking noise, not belts
S
shoehornhands
7
Hey everyone, first post here, thanks for looking.
I swapped a 1970 Olds 350 into my Monte, built the engine myself, my first time ever doing so. Got it up and running but it's making a horrific squeaking sound, which you can hear in this video:
There was no change to the sound when I ran it for a moment with the belts removed so I know it's not a belt or a pulley. And I do have adequate oil pressure.
I need to do some more poking around, maybe with a stethoscope, but I'm on the road driving a truck right now so I was hoping you guys could weigh in and let me know if it sounds familiar or if there's anything in particular that you think I should check. Thanks
  • Winner
Reactions: fleming442
565bbchevy
565bbchevy
7,006
Michigan
It's just your Monte screaming because there is an Olds in it's engine bay and somewhere there is a Cutlass screaming because someone put a SBC in it.
83StreetMachine
83StreetMachine
141
Central NJ
Ok. Out of curiosity, do you happen to have a metal flexplate cover on the trans?
Did you pull the valve covers while it was running and making the noise?
S
shoehornhands
7
No, it's uncovered right now. And no, not yet. Are you thinking bent pushrod? Broken valve?
I keep looking stuff up on YouTube and I find a lot of knocking videos and not much squeaking. Very frustrating
565bbchevy
565bbchevy
7,006
Michigan
I personally don't hear anything that would suggest valvetrain noise.
I would like a new video with no belts and enough light to see the engine.
