On the Cheap chasing an 8.50
Data is always cool. Shows how much refinement there is between a 9.99 car and a 8.99 car even with generally the 'same' setup
Interesting the big treadstone IC is the restriction.
Got any more drag and drives planned for the next year or still settling in from DW?
Post Drag Week 24 review of data.
I'm out of intercooler. I knew I hit a timing retard due to IAT temp on the last day, but reviewing logs from day 3 and day 4 found I hit as well on the 2nd runs from each of those days as well. I had the timing retard set too high (too aggressive), and that was the cause for the slow trap speed. It does affect the ET as well, but not as dramatically as the trap speed. When I first seen this, I was somewhat disappointed because this is usually an indicator of being out of turbo compressor. But after looking at multiple logs I noticed the Pre-IC pressure vs Boost was in the area of 6-8 psi. Basically it's a measure of IC flow restriction/capabilities. This intercooler is advertised as having 2-3 psi of pressure loss across the cooler, but it's always been 1-2 psi higher than that which isn't good. The larger the differential, the higher the pre IC temp and IAT. The IC is pulling 250-260 degrees out of the intake air.
This can also be a function of head and cam flow as well, but that usually is found to be the issue when no increase in trap speed or faster ET despite adding more boost and using more fuel. I contacted BTR and asked about cam specs and how many rpm's I'm running on this setup. They advised that the cam is too small and adding to this issue. But they agreed that I'm out of IC as well. My IC, Treadstone 1340R, is rated for 1300+HP and it's obvious that number is a bit lofty. The issue doesn't develop until I hit 29.5-31 psi which s about 1100 whp (1200-1250 crank HP). The last couple of days I was running 1200whp and the lack of Intercooler capacity was illuminated.
There are a couple of things I can do to slow down the IAT temp - better intercooler or put the meth injection back onto the car. One of those options will cost me money and the other won't. I have a complete meth system that was on the car until this past winter that I removed to drop weight. I decided to pull it off based on dyno testing that showed my Pre IC and MAT readings were 30 degrees cooler with this turbo, so I decided to pull it off. The next thing to do is put in more cam. BTR indicated to swap out my Stage 2 turbo cam and put in a Stage 4 turbo cam. The difference between the two is about 14-16 degrees of intake and exhaust duration. And they only recommended a stage 4 rather than a stage 3 based on the compression (11:1). But drivability might go in the toilet with that large of a cam at 2000-2400rpms - hmmm, what to do?
Also I still have an issue with the the converter being too tight. Last fall Circle D had advised to put more power to it to loosen it up some. Well, I added 150+ and it still is dropping 1200-1300 on the 1-2 and 1100 on the 2-3 shift. I've contacted them and they said they could build a custom stator for it and loosen it up some more. It's either try that or drop $2K+ for a bolt together converter - $2K+ is definitely not in the budget.
I'm sure that if I could've gotten another 3-4 runs in I could've been running low 8.8__ and possibly a high 8.7__. It's amazing to me that every time I manage to grab another 100-200hp I find numerous weak links haha. I guess that's how it goes. But I'm getting closer to being more competitive for an 8.50 chassis cert. I'll try to get some videos loaded onto YouTube identifying another issue that I have as well.
Is there a 'line drawn in the sand' for you regarding this?
That is true. You can drop speed immensely and not have it affect ET by a whole lot at the finish line. I've killed 30 mph on the brakes and not knocked ET down by a few hundredths.
I didn't realize how much this is the case. I feel I would've been 5-7mph faster if it hadn't cut timing for the last .5-.6 seconds of the run. It slowed me down enough that I didn't think I went as fast as it did.
I refrained from signing up for Sick Week only because of the expense end of it. Also, it's almost creates no off season to make upgrades. When I went to SW in '23 I showed up with too many untested changes and that sucks - trust me. It's definitely much more rewarding to show up with something that is tested. On test day, Sunday, I had the new to me tires and the new shocks. I ran multiple passes but only to the 330' with the knowledge I know I can get the car down the track past that point. I plan to do DW next year, but I'd like to do another. I'm just not sure of which one. I have to admit that finding ones that are less than an 8-9 hour drive from my home is nice for travelling to and from the event.
I'm somewhat surprised how the IC has worked out. I thought it would work better, or not have such a sharp point where it goes from good to bad. Perhaps some of it is in my setup too. The little SS grill doesn't help.
Yes, the cage. And I've been fortunate IMO with the transmission. I feel that I have to be nearing the limit of the stock input shaft and sprag. The next level of upgrades for that component aren't cheap. Of all parts of racing/going fast, the transmission is the one part that I can't handle. I'm old enough that I don't have 3-4 years to learn how to become a transmission guy despite that I would like to.
finally.. someone that practices moderation..moderately of course😉
It's all relative. I wish I knew what I know now when I originally put this car together.
This thread is getting quite long, not at the 100 page record to convince me that I need a cam, but it's long enough. If someone took the time to read through it to see the stages of the car and all of the things that I did that I could've done better the 1st time around, then they would know that I've lived and learned. And I'm sure I still have a lot of learning to go.
I've spent alot of time and effort increasing slowly. Read through this thread and skip my 1st 5-10 levels of guessing at what works and what doesn't lol.
Gotcha. I'd be right there w/ya. At some point, it beomes no longer safe on the street once you get too aggressive on the safety stuff for the track.
don't give it a second thought. I ran my car in various combinations for 22 years. They were all variations of the last combo I had using parts as I had them and making changes as I went. They didn't all go quicker either.
I was looking at a Holley Hi Ram and BTR Stage 4 turbo cam. About $1300 for the two (ughh).
I couldn't bring myself to spend $900+ for an intake, so I'm trying a $3__ Summit setup Max EFI tall runner intake. Word is it should get me another 30-50HP, but time will tell - I'll be testing before too long. I have some previous data at 23-24 psi that I should be able to replicate to see what kind of difference the intake makes vs. the previous Trailblazer SS setup.
This required new intake piping due to the angle of the TB changed with this intake. So that means there is no going back to the Trailblazer because I had to modify the intake piping. Well, I could go back, but new aluminum piping purchases and fabrication required. I'm thinking positive - this will be a bunch better and I'll never go back 😉
So I was onto cam buying. I had spoke to BTR and had 'a guy' to help me out. I spent 30 minutes on the phone with him and explained my setup and situation. He recommended the Stage 4 only because of my rpm range and compression. He advised he expected another 100-150hp at 30 psi with the Stage 4 cam. So I want to say, I'm a true believer and buying from vendors that spend the time to help/guide me. But..............
Lunati, owned by Comp Cam, is selling LS cams for $180. The card attached is similar to the BTR I was going to purchase. It has a little bit more intake duration, but a little less lift and a couple of other numbers off by a few degrees. Bottom line, it's similar enough for my junk and almost 1/3 of the price of the BTR. The lobe intensity is very mild imo and should be able to street drive without skidding lifter wheels (I hope 🤞).
I'm planning on a race at the end of December at Maple Grove (weather permitting) with only the intake swapped. I don't expect much knowing it will be cold as heck and front side no prep. It should be a good time, but not record breaking lol. After that weekend I'm onto trans and some rear suspension upgrades.
