Original 78 parts???
Cla66640
8
4
So as I move through my rebuild I've just about gotten through stripping the engine. It's the Buick 231 V6. In all honesty I plan on replacing just about damn everything other then the block itself to get some level of aftermarket performance out of it. So I was wondering if anyone has any advice on the market for the original engine parts? For the most part the major components I've stripped thus far seem to be in surprisingly good condition. Is it worth my time to sell them off?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
69hurstolds
8,198
17,599
I would imagine that everyone would be doing what you're doing, so the demand for stock paperweights would be very low. There may be a chance someone might take them off your hands that perhaps is rebuilding their stock engine for whatever reason and dropped and damaged a piston. Who knows. Put them for sale, see what happens. If they're not selling, lower your price until they do. Which may probably still be more than a barrel of crude oil right now.
lilbowtie
3,460
3,965
Canton Mi
If you some how got a 50% improvement in power you still wouldn't have anything. Your at the point where a SBC would be a wiser - cheaper way to go. Are you sure you have a Buick engine?
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Dont the brackets fit small block Buicks?
If they do I would keep/sell those
ck80
Moderator
Moderator
5,743
9,121
I'm going against the grain here and saying "it depends." BE REASONABLE and you can sell much of it.
Intake and carb - these have value. Carb is non computer control, and guys with malfunctioning computers or removing emissions like this. Price it as a core because anyone who buys will want to add a kit and rebuild. Intake has value, but less of it. Not every 2bbl 231 intake was created the same. In later years they used an efe heater element between the carb and intake. Some intakes were notched for a recessed version of the efe heater plate (which over time could melt/fail.) A VERY limited market would pay a couple bucks to replace their intake with yours, but, lower desirability.
Exhaust manifolds - not worth much more than scrap. Wouldn't have the O2 sensor molded in, but, most people would put something better than the cast iron on. You could get a few bucks, but if imagine not alot.
Engine accessories - not worth much. Take what you can get but be cheap. Not worth much more than core value.
Engine brackets - usable on a buick 350, lack of an air injection reactor (a.i.r.) system pump mounting points helps clean up the appearance, but, sounds like you're reusing those anyways.
Anything else? Again, not worth much. You can get stronger 2 dot cast rods from a turbo motor for around $10 each. So, not much incentive for yours if you're removing.
Not sure what else you think may have value, but, if say $50 on carb, $20 intake, $10 exh manifolds, and core value on engine accessories covers most of your values, at least in my opinion.
