Installed drivers side handle several times now. Handle is raised up on the outside. The rod from handle to latch is straight but when putting it on handle attachment point it pulls outer handle up. Actually searched here and read some good advice and I believe my latch is gunked up. Prior to paint I attempted to remove latch assembly to no avail. Tapping on large Philips while turning did nothing and started to strip heads. Question is what would you do to free up mechanism? Spray wd40 while working inside handle? Or something similar 🤔
Latch works fine with inside handle
Kind of a conundrum
Kind of a conundrum
