Re: Overheated my 406 and im ripping it apart. Have some que
Very unfortunate thing to happen 🙁
The loss of oil pressure is most likely due to a bearing failure. Especially if you are getting oil pressure with engine RPM higher than idle. Hopefully you'll be able to get away with a crank polish and new bearings, be sure to do camshaft bearings as well. The way I always look at it, if you are tearing the motor down and inspecting everything, might as well replace the bearings/rings while you're there.
I have a Felpro Performance book at work, I will get you a Felpro part number on Monay morning
