As said above...single plane intakes really only benefit from 3000rpm and above, which defeats the purpose of a street car that has good idle manners and vacuum.
You would benefit much more from a decent dual plane such as an eddy air gap. I had a weiand stealth when my 355 was carbed, stock bottom end...but the intake was good from 1500-6500rpm. Ran a 650 street demon carb, cast heads with 2.02/1.60 valves, decent headers, etc. That motor had plenty of grunt outta the hole and pulled hard to 7k without issue.
Note...i was running a summit 1107 cam which was 232/242 duration, .488/.510 lift which was too big for the converter to match....but i drove it daily and didn't want it revving high. However, once the motor hit the cam powerband around 3400rpm, it would stick me in the seat!
