The foot high box thing is a great tip. Build some boxes like that with a step so the scale pad can be at one end and a flat spot to the other. So you can move the car back and forth onto the scale pad. Make sure you get wheel chocks for when you're under it. Never let anyone roll under without the chocks in place.
Weight outside the wheelbase is bad. Weight on the axle is ultra bad.
Unfortunately your left side weight is helping you a little bit right now. You need to get that down since you'll be up front and be in tech. 😀
I'd shoot for 52% cross weight. Cross below 50% really helps the car turn well but on these big cars is an invitation for a loose condition 15 laps into a run.
We had good luck before melting lead into a cookie sheet. It was really thin (obviously) and could be formed and placed under the floorboards and lining the driveshaft tunnel. We always had to paint our lead white and put our number on it.
Did you measure your ride heights? How is the car sitting? Do you have ride height adjustment via weight jacks or shims?
ramey
ramey
