I'm trying to install my piston rings, and have come across a slight problem. I noticed that on all the rings, there is one inside edge that has an inside bevel. I also noticed that there is a dot on each ring, which should be facing the top of the piston. However, on 8 of the rings, the dot is on the same side of as the bevel, and on the other 8, it is opposite. My question is, which style goes in the top groove, and which goes in the bottom?
