pitman arm
flyin brian
8
1978 malibu just picked up a manual steering box .wondering what pitman arm can i use. or can i use powersteering one thanks
flyin brian
Thread starter
Jun 13, 2021
8
not sure i was told it will fit gbody
should i see if there is numbers on it
1320John$$$
922
Pennsylvania
Count the splines on the input shaft and mike it or measure with a tape to give us an idea of its thickness
JAMCAR223
1,711
Houston, TX.
IF you had the "small" 605 power steering box on your 78 ( mine did ), then your 605 pitman arm will fit your manual steering box (1" spline diameter). IF you would have upgraded to the "large" 800 power steering box, you would need a different pitman arm (1.2" spline diameter).
1320John$$$
922
Pennsylvania
If he has the 525 box he is going to need more then a pitman arm
ELCAM
166
Is the steering shaft 3/4" with 30 splines?
5679206 is a 60s A body box. Should be a 525 with 25:1 ratio.
Looking at a 72 A and my 79 G the pitman arm looks the same length and offset, don't know about the tapers on the drag (center) link.
The rag joint will also be a different size
G-Body Performance Upgrades
