I have a 1984 Monte Carlo with a 7.625 rear in it that I just bent the driver side axle. I need a 9" but I don't want to necessarily get one off quick performance because that's going to cost $2,000. I've heard that the only thing you have to do is find a 66-77 bronco and yank the rear out of it because they are 58" like the gbody. They are supposed to be 31 spline already. My question is, is all you have to do is weld the suspension brackets on it? Or is shortening and customization necessary? Both are 58" I know one side of the aftermarket 9" housing for the gbody is shorter than the other. Is the bronco the same? Please help I'm about to pull my hair out.
