jonnyslick said:^ Tony ... What rims are on your car? (brand)
Centerline Retros
Tony_SS said:I would go with chrome then. Easier to clean plus it'll look good against a dark color. I dont think you can get the Coys in a 17x9.5 though. Might have to do 8" all the way around. If so, I'd run 4" of backspace. and 245/45-17 up front and a 255/45-17 or a 255/50-17 out back.
JDub said:Tony_SS said:I would go with chrome then. Easier to clean plus it'll look good against a dark color. I dont think you can get the Coys in a 17x9.5 though. Might have to do 8" all the way around. If so, I'd run 4" of backspace. and 245/45-17 up front and a 255/45-17 or a 255/50-17 out back.
Okay, i think i found the wheels i want. 17x8 all around, but with a 4.5 backspacing. is that too much? basically that means the wheels would stick out farther than a wheel with 4" backspacing right? thanks!
Tony_SS said:No, the more backspace you have, the further the wheel sets in. 4.5 should be OK for you though. If they have 4" of backspace go that route - I know it works. But 4.5 should be fine - I know it will be in the back, but it should clear everything up front.
What wheels did you find?
