i suspect the cam is worn in my camaro.. runs fine.. drives fine.. pops under load... sounded like a miss when your in the car...but under load under the hood with the air cleaner off it appears that its popping out of the carb.. i think i seen some unburnt fuel as well..
sound like a cam?.. or is there anything else i should check?
timing is good, new wires and plugs... hei and ignition seem to be working ..
car works fine as long as your easy on it... will rev to 5k as long as you don't punch it.
SBC and a Q-jet... i also adjusted my needles as they were lean IMO..
