I have an 84 Regal with a plain (for the time being) sbc 350, th350 trans.
It has the GU1 7.5" rear end, which I believe is the 2.43 ratio. I found a GU1 G80 rear end and was wondering if it was worth it to grab it and have it swapped into my vehicle? It is the same ratio... unfortunately.
If it was a lower ratio, it would be a no brainer. Would the diff gears in the posi 7.5" fit and work in my non-posi rear diff case?
I'm probably not going to get it due to the high gear ratio (as this is a street car and not a highway car) and the rear diff I have now has 65,000 miles on it. But I'm curious if I could swap a posi diff into a non-posi diff case? Are the cases and axles identical?
D
D
