hello and how ya doowing? Did you drive your car with the stock pump at all? I've been driving w/the HB a little while (stock pump) and is feels different than the PM. My pedal is higher and it's a less control feel maybe I'm nuts but I'll bet the higher output pump is the way to go.Yes , had my stock pump sent out to Turn One in Michigan for modification.
They installed AN fittings and also adjusted the PS pump for optimum performance for HydroBoost.
Give Junior a call.
My pump had the flow rate (gpm) and output pressures raised to 1850psi and 2.9 gpm
Works great on my HydroBoost system now.
I also installed a PSC power steering fluid reservoir which is ideally suited for the HydroBoost set up.
Not cheap but at the end of the day works fantastic.
The juice was most definitely “worth the squeeze”
