I've done almost all the work on my Cutlass and would like to have a hand in the paint job as well. That being said, I'm considering all my options. Thanks, guys!
tape the panel gaps to keep the stripper out of the jambs.throw plastic sheeting on top of the stripper to keep it from drying out on you.i find it works better that way.CHEMICAL STRIPPER!! Saves allot of elbow grease.
I use air craft remover and a brush, staying about a half inch away from edges just door or trunk jambs. Unless you plan to strip those too.
Once the paint wrinkles, I scrape it down with a body filler spreader.
Once dry, then I DA with 80 grit.
