ok the car in question is my 79 regal. previous owner swapped a sbc engine in it but i dont think it has anything to do with my problem. i'll try to explain it in the order this happened.
i tried out the fan switch to see if the blower motor worked and it didnt. so i checked the fuse and it was blown. i replaced the old one with a new fuse and the blower motor kicked on like it should. once the blower took off it sounded like something was shorting it out. the motor wasnt staying at a constant speed, it was acting like it had a drain on it for a split second then was fine and kept doing that constantly. after about a minute of the fan running the light blue wire behind the hvac panel started to get pretty warm so i turned it off. i also noticed the large orange wire on the plugin was lightly burnt but it wasnt warm, just the light blue wire. so i pulled the fuse out and it was pretty toasty warm. i looked at the fuse block itself and where the fuse sets in place it is lightly melted. the only setting that does not work is high speed when selected by the switch. but now my biggest problem is that you can select the fan speeds with the switch and hear a clicking sound coming from the blower motor relay but no blower motor movement.
so does this sound like the blower motor relay is shot or is it something else in the wiring harness maybe? maybe the resistor? i looked the best i could for a bare wire inside and out of the car and could not find anything.
