David Williamson said:
It seems I have the most posts on this site how many times I need help cause my car doesn't want to get fixed.
Or you just don't know how to fix it... you don't even know what kind of trans is in your car but you want others to help you fix the problems. I think there is a bigger problem here than just the car... :lol:
I am just getting tired of this project, which was never suppose to be a project but turned out to be one when all these problems arose.
All cars are a project, that is why it is a hobby rather than a necessity. You don't see people driving Model A's around to work :lol:
No offence but from reading all your posts it seems like cars are just not your thing... some of the simplest and easiest fixes that just take simple engineering, ingenuity and know how you have difficulty with and make a bigger deal than it should be.
In general it's hard for other's to fix your car through a keyboard and a computer screen and it can be frustrating for some to try and help when they are not there onsite.
Also, you can investigate and trouble shoot your issues by using Google or a simple shop manual and try to pin point and rule out the issues... trust me, folks on this board want to help but at least try and take a stab at doing a little research first and become familiar with the situation, it will make things go a little smoother.
Your car could be bogging for a few reasons:
Vacuum leak
It's possible your lockup might be stuck, just simply drop the trans pan, unbolt the lockup solenoid and replace with a new one. Probably an hours work and 2 hours of prep and cleanup time... but like you I'm not sure what kind of trans you have.
The carb needs to be rebuilt, could be gummed up or the accelerator pump is no good.
Bad gas, catalytic converter is clogged, EGR valve is stuck, etc... don't know unless you start to tinker and explore with trial and error and that is what this hobby is all about, Ingenuity and a good set of tools.
