I got a used carburetor off ebay its an edelbrock 1406 I believe (600cfm).
In the description it just said "needs to be freshened up" whatever the hell that means.
Anyway, I got the carb, the fuel inlet looked dirty and I unscrewed it and it was caked inside with some kind of grey crap, I cleaned it out with an air tool and some carb cleaner stuff (actually i think it was brake cleaner).
I put the carb on the car and notice the linkage doesnt provide anyway to connect to my TV cable or throttle cable..thats the first problem
I start the car up after connecting the electric choke which seemed to be fine, opened up a little bit. it seemed to run fine but its idling high. I noticed when the carb was off the car I had to mess with the linkage a little bit to get the second set of throttle plates to open up at full throttle (i cant really explain it but it looked like the electronic choke might allow for that linkage to make room and work fine).
SO...I try to rev the car and it seems to be acting weird when I try to go full throttle. when I let go of the linkage (tried this many times) after reving the car stalls immediately.
this morning i went out to mess with it again. I didtn really let the car warm up to be honest, and tried to just rev it high up repeatedly and see what the problem was. i couldnt really tell if it just wasnt feeding fuel fast enough, that was my best guess. well as i was revving for a second I notice alot of white smoke that seemed to be coolant coming from the rear passenger side of the motor. the only thing i could think was that I blew a headgasket or something...why would COOLANT come from that area like that all the sudden? I started the car up again and the coolant burned off and didnt reappear or seem to be leaking anymore. It might have been my paranoia but I started thinking the motor was making an abnormal noise like sort of a low whine.
I started the car a few more times (kept stalling when i was trying to adjust the idle) but the battery started dieing and its not old either (neither was the one I replaced before it). I think I toasted the battery which is really the least of my worries right now, i'm gonna go exchange it at walmart in a minute.
was hoping to get some opinions from yall about what could have happened. I was probably ignorant to think I could just slap this carb on but I figured it couldnt be any worse than my quadrajet was. How hard are edelbrocks to rebuild? i see the kit at Autozone...I'm just not sure what I need to do here. and I'm worried about the coolant surprise too. thanks guys.
