PROJECT " LAID BACK 2 " - 1978 SALON 2 DOOR AEROBACK
HUGE RELIEF !! The broken bolt was NOT a broken bolt. It ended up being debris clogging up the bolt hole. I had my copper tube & welder set up. But I also had (4) sizes of hardened left hand drill bits laid out, and decided to use my center punch to get my drill bit centered. I tapped the punch with my hammer, and the punch fell to the bottom of the hole. WTF... I cleaned the hole out with a pic, compressed air, a few drops of oil, and my thread chaser. (5) minutes later, starter installed, and bolts torqued. THANK GOODNESS! I knew I had not missed that before taking the block to the machine shop, and their block inspection sheet did not mention it. I assume it happened while cleaning the block. I had been stressing over this all week. Moving on...
I guess my reverse rotation water pump was one of the last cores on the planet. Everything is still moving at a snail's pace.
I still have a cast iron reverse rotation Olds diesel water pump that I am probably never going to use. James, do you want it? Just pay shipping and I'll send it to ya. Let me go get it it and check it to make sure from sitting that it doesn't have any problems. And I'll get some pics. Anything I can do to help get this engine done and in the car!!
Here it is. It still seems to turn nicely.
A little cleanup and paint and it should be good to go.
Joe, that is very generous of you! Yes, I would love to have it. I'll be honest, I will send this casting to Flowkooler, and have them go through it, and install their upgraded aluminum impeller. Take it to your choice of shippers, and send it. I'll pay you back that same day. I'll text you my address. No need for you to look back through our previous transactions to find it. Big thanks to you!! 👍 👍
Speechless at the generosity that several Forum Members have shown me. From going to look at parts for me, going to buy parts for me, shipping parts to me, and giving parts to me. You guys know who you are, and I give you all a very heartfelt thank you! I have said it several times before, and I will say it again... This is the best group of guys, on the best Forum EVER !
