BUILD THREAD Project long time coming
Curious to how much the front spring compress at ride height
Not sure how I can get a true reading on that. Way too low to be able to measure on the ground. Maybe when I get an alignment this spring and it's on a drive on lift.
Once I can actually start trying to race it more, I'll probably go to 1k, or 1200lb front springs
How high can you go before you overwhelm the shocks?
Simplest...
Put a zip tie on the shaft against the shock body, set car down, lift car back up measure distance the body shoved the zip tie up the shaft... that's going off the spring is at least snugged against the mounts and no major preload of the spring at full extension.
Im going to nerd out a bit here...
Take travel length times spring rate that will give you your ride height spring weight..
Example 2" of compression at 750lb/in is 1500lb per corner.
IIRC a 2.5*10" spring has roughly 4-5" of travel before coil bind.
With 1:2 shock to wheel movement ratio.. 2" on the shock is 4" on the wheel.
If you go from 750 to 1200, your spring travel will reduce to 1.25" and wheel travel will reduce to 2.5"
Pro to less wheel travel, less likely to have body roll
Con to less wheel travel, more likely to pull tires off the ground in bumps/turns
The latter does make for good action shots😂
Simplest...
You'll only lift a wheel by eliminating down travel, not by changing spring rates.
Simplest...
I scaled the car a LONG time ago. It had the SBC and M21 at that time, and stock suspension. Somewhere i have the weights. IIRC the LF was the heaviest at 897 pounds, RF was over 800lbs, LR was 700 something, RR was the lightest at high 600lb range. Total was 3201lbs. I'm sure it's weight distribution is better now, front to rear, and left to right. Overall weight is probably pretty close, maybe a few pounds lighter.
New coilovers are installed. I'll have to set the ride height once it's back on the ground.
The transmission is on its way back, should have it next week, so hopefully next weekend I can install the drivetrain and start hooking it all back up.
Guess there is an issue on the page, I can't add pics at the moment GP403
  • Sad
It's back! Time to get hustling. Hope to have the drivetrain dropped back in the car this weekend, but it's going to be tough as we have a few other obligations as well.
Needed much more than I knew, and was hoping for 😢 but it's done and upgraded as well. Carbon fiber synchros, billet shift fork pads, and steel 3-4 fork. Of course bearings, seals, etc in addition to 2nd, 5th, and 6th gears, input shaft, cluster gear, all three synchro sleeves, and they repaired the main shaft journals.
