Project Wa~Gone
vwdahn
30
2
8
Gladstone Michigan
http://www.amazon.com/Sheet-Metal-Handb ... 0895867575
Thank you :) I had a lot of help/advice from fabricators.
vwdahn
30
2
8
Gladstone Michigan
Does anyone know a Paint I should use for the interior sheet metal Inside/outside? I would like to stay away from spraying it on and a texture'd look is not out of the question. Suggestions?
Thanks
vwdahn
30
2
8
Gladstone Michigan
update time
Decided to go with a 76mm turbo, EFI megasquirt MS2 Extra. That should help the 4.8 out out a little :)
vwdahn
30
2
8
Gladstone Michigan
I will install the intercooler and bumper tonight :) Intake,Deka 80's and the rails are all on so an update will be soon.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,186
9,822
Gainesville, Fl
It should be quite a lethal machine when it's done. :twisted:
vwdahn
30
2
8
Gladstone Michigan
Thanks LONGroof! I will give away all my tunes also when i get it going :) and the build sheet with all the links and prices to the parts I used. its quite cheap HP/$$ if it performs.
