Here I'm dating myself again. In 1975 when GM switched over to the HEI system, failures and call-backs were very common. The prevailing wisdom at the time was to keep a spare module handy. Although I don't know what good that was without the tools and the talent to change it out. But as time passed the culprit was identified as heat from the distributor body affecting the module. It became obvious because when the engine got cold it started right up. The problem was so intermittent that it took a while to nail down a fix. That fix was the dialectic grease that was schmeared on the underside of the module. From then on, replacement modules came supplied with a little pill of that grease. I have to say that I never experienced a module failure but the pickup coil was my bane.
