The hardest part, will be aligning the primary metering rods in the jets. That's it. Top lifts off like an edelbrock, just gotta knock the accel arm roll pin back (I use a dime inbetween the roll pin and air horn so I can still wiggle it back in), undo the choke rod from the air horn, undo ALL 9 screws (two under the choke flap).
The most expensive and time consuming part, is the throttle shaft bushings. You can send your baseplate to everyday performance, among others, and have them do it, but if you have a dremel, the bit, and the bushings, it will take about 20 minutes. You need to dremel the staked backsides of the throttle blade screws off so you can back them out without snapping them or mangling the holes.
I have the bit, it was $30 dollars, it's a fluted reaming bit I actually chuck the flute part in the drill and run it backwards. The smooth shank goes into the throttle shaft bores and it self aligns. Bushings are $20 for a set of 10 (5 carbs worth). Usually when I rebuild them, I don't do any modifications internally like drilling out passages. I buy my parts from Quadrajetparts.com, usually ends up being about $100. Rebuild kit (gaskets, needle, seat, lil bits, might have an accel pump check ball), float, accel pump (I don't use the accel pump rebuild stuff, i buy new), o-ring well plugs (drill out the old ones carefully, tamp these ones in, I then epoxy over them, alternatively you can chop up some bolts, slot them for a screwdriver, and run em in), etc.
Plus the QJetParts kits come with all the instructions on how to setup the carb, what level the floats should be, etc. really neat stuff.
