Hello peeps!
Old(ish) member here working a new build and I figured I'd document what I'm doing as I do it. This is gonna be a fairly long term build so I will be working on and off on it as time/money/energy allows.
About the car:
So this is originally a Kuwait export model 1985 Olds Cutlass Supreme Brougham. VIN says it was built in Quebec, Canada as a lot of Gulf-spec export GM sedans/coupes were at the time. Factory drivetrain was a Chevy 305 SBC, 200-4R trans and a 7.5" rear open diff. Originally a soft top car that has been converted to a hardtop. Has factory A/C, 60/40 front split bench, column shifter, cruise, power everything and a metric Rally gauge cluster.
Plans:
As the title suggests, the plan is to restomod this G body and hopefully end up with a fun comfy high hp cruiser that I can daily.
Drivetrain:
2013 4.8L L20 pulled out of my 2013 GMC Sierra (built and swapped a 6.0L L76 into that truck).
2004ish 4L80e from the junkyard
Ford 8.8 rear diff pulled out of a junkyard 1990 fox body
I don't actually have much pics of the car itself, mostly just the parts and engine bay/underside which I took while working.
Started this build by yanking out the old drivetrain and anything else not needed. The frame and floors are all solid except for a section of the trunk area which has been fixed.
As you can imagine the engine bay was nasty. Almost four decades of harsh desert climate has taken its toll on the rubber and plastic. A leaky steering box spraying fluid everywhere didn't help either. The plus side is the firewall and floorboards appeared to be completely rust free once cleaned up.
After several sessions with a pressure washer, degreaser and good ol elbow grease.
To be continued...
About the car:
Plans:
Drivetrain:
To be continued...
