Qa1 pro Coil over front issues
Cj81bu
n00b
Aug 11, 2019
2
Hello I’m looking to see if anyone has had similar problems with the qa1 pro coil over conversion. This is on a 10 second 81malibu sbc bracket car I’m having inconsistent traction that never happened before with trick springs and stock a-arms. I have global west tubular a-arms with the r series single adjustable front shocks. I have tried the new longer travel springs but still seems like there is little travel or energy in the front. If the track is prepped good then it’s not much problem but if it gets late and the prep goes away I spin at the hit and loose .03-4 in the 60 fts. If the car is at rest and I push down on front it will stay there til I lift up, if I lift it stays up ?
Anyone had similar experiences or ideas for front shocks and springs with keeping my current a-arms ?
bracketchev1221
1,415
1,653
Sorry, no need for coil overs on the front of a 10 second car. Nothing works better than stock type coils and shocks. You can’t get the travel and make it loose enough with coil overs. I ran stock a-arms with rubber bushings with single adjustable strange shocks and trick springs. Went 1.21 in 60’ and 8.80’s in my 3200 lbs chevelle.
Cj81bu
n00b
Aug 11, 2019
2
That's what I was afraid of I have the old single adjust shocks and trick springs but pitched the stock lowers. The new lowers are not setup for stock springs.
bracketchev1221
1,415
1,653
For years I looked at changing out my front pieces to save weight but could never justify to cost to savings when what I had worked fine. I ran my car for 22 years from 11.20’s to 8.80’s and just slowly modded what I had. Started with trick springs and 3 ways, then to koni spa-1’s then strange single adjustables. But never could make the move based on how heavy my car was and how it ran.
