Quadrajet Choke not open all the way at Operating Temp
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,993
Socialist NY
why do u say the element isn't bad? the spring might have lost is "sprung" and even though visibly it looks good it isn't.
8,829
7,786
Melville,Saskatchewan
I would pull it apart. I have seen where the rod slips out of the coil and doesn't engage/disengage properly.
MrSony
6,837
6,755
Des Moines, Iowa
I've had it apart dozens of times. The element is just as springy and in the same shape as all the others I've tested and have.
MrSony
6,837
6,755
Des Moines, Iowa
I have 5 stock quadrajets that have never been messed with, and the choke is all set up EXACTLY like mine is. I have no idea whats wrong with it. I may try swapping the housings in case the linkage is bent or something stupid like that.
TURNA
Jul 24, 2009
10,941
19,993
Socialist NY
if you have 5 others why not try one of the others and see if that solves the problem????
pontiacgp
blank
Mar 31, 2006
29,270
20,413
Kitchener, Ontario
you tested the volts but did you make sure the ground is good on the plate the spring sits on?
