I personally like the electric choke better, much more adjustable and less finicky for the correct setting. Just use something easy to remove when blocking the holes like RTV. I used JB Weld because I am never going back to hot air.
You are correct, but it is a controlled vacuum leak when connected to hot air coil. Brake booster is a vacuum leak also, but controlled as well. Not the same as leaving it open. All open vacuum ports should be used or plugged.
As I mentioned, you might possibly need to create some additional bypass air if you have a modified engine. Stock will probably be fine without needing additional bypass.
True enough but there is a very small range where it will work correctly. Maybe it is the ultra lean mixtures on some of my cars and so many months with days below freezing or close to it here, longer choke time helps with the running. I have to say my 260 works quite well with the stock hot air choke. Plus the coil is stuck in place so I can't mess with it🙂. Maybe it was the pull off that needed adjusted on some of my cars when I was young. I just had bad experiences, including seeing rotted intake tubes, maybe Olds was on to something, they stayed with it to the bitter end.
