On my 800 cfm quadrajet I have changed the hot air choke to electric because my intake does not have the provisions for the hot air. I would rather use the hot air choke cause I think it's more accurate than the electric. Reading Cliff's book the he suggests to block the air passage to the carb in the choke housing if I am converting it to electric. I was under the impression the carb was set up to use that air and it should not be blocked off. Anyone have any opinions on leaving the hole open or plugging it?
