Question on wheels and tires for 83 cutlass
83oldsrr
n00b
Jan 20, 2018
I have an 83 Olds Cutlass Supreme. I am currently running the stock 14" rally wheels and stock tire size. I want to upgrade to a 15" wheel. I want to put 15x8 on the front and 15x10 on the back IF I can. If I can do this, can anybody tell me what the exact offset/backspace I am going to need on the rim so it will work?? All suggestions are appreciated but cutting into the car is not an option.
UNGN
3,048
3,264
Southlake, TX
Don't bother with 15X10's in back unless you have notched the frame. Not much advantage to a 10" wheel unless you can run a larger tires and the current frame/body won't let you. 15X8's with 4" BS in back is your best bet.
15X8's in front are tricky, because the correct offset to clear the inner fender lip hits the tierod ends/ control arms. 16X8 or 17X8 wheels fit a lot easier in front than 15X8's. 15X8's the don't rub the suspension may need major inner fender surgery.
Of course if the car is jacked way up in the air, larger wheels & tires won't rub, but that completely defeats the purpose of larger wheels/tires.
565bbchevy
9,614
12,683
Michigan
If you are looking for a staggered look try 15 x 7 in the front and 15 x 8 in the back, this will eliminate any fitment issues with the wider front rim.
83oldsrr
n00b
Jan 20, 2018
Would there be an offset for the front or would it just be 0mm if I went with 15x7 in the front
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Just run 0 offset. In this pic I was running 15x6 front with a 26x8x15 tire, and 15x8 w/ 4.5" BS and a 235/60/15. The backspace on the rear was almost too much! The tires were really close to rubbing the frame.
DoubleV
2,154
406
83
Medina Ohio
I may be interested in your old ugly 14" Rally's 83oldsrr....
83oldsrr
n00b
Jan 20, 2018
I will let you know on that because I don't know quite yet if I want to get rid of them. They are a complete set and there is absolutely nothing wrong with them. But for the right price everythings for sale, even my ol lady:rofl:
