I bought a really nice 442 last spring and I have been questioning myself if it is an original 442 or 1 that was pieced together. I really wanted to try and get the CCC system to work properly again and keep the car as original as possible, minus the headers I added. I am really torn between trying to keep it original or rip the 307 out and replace everything with something better. LS ? The vin and body tag on the firewall both confirm that the body is a Vin 9, but according to my RPO codes on the trunk lid it shows items that my car doesn't have. I should have a power antenna, but it does not exist. I have the floor shifter, but my steering column was from a column shift car. it doesn't have the lever, but there is a chrome cover around where it should have been that rotates when I shift from the floor. The interior trim on the TTOPs is maroon instead of grey. The front bumper has what looks to be junkyard markings, I'm sure Olds didn't mark the bumpers "87-88 Cut" at the factory.
I also bought an original GM Service Manual and noticed that the wiring diagram for a VIN 9 doesn't use a Anti Dieseling Solenoid, but I have the wiring and plug for it next to my carb. I have been tracking down other issues with the electronics behind the dash, not sure if my ECM is bad, or if there are other sensors bad under the hood. There also seems to have been quite the hack job to most of the wiring under the dash from looked to be an older alarm system.
I guess I'm just looking for suggestions. I love the car, just want to be able to enjoy the hell out of it without fighting a 32 year old computer. What would YOU do? and no I do not have an unlimited budget.
