Haha, oops I sure did lol! Good catch!If this was from guys comment I think you misread it.
It clears with my BBC and my long water pump is mounted with studs, it's tight but I can slide it off with the fans in place.Intrepid/300M fans work pretty good with most G-body applications, except maybe a big block with a long water pump. You will have to build your own brackets, however.
Not to nitpick, but mine is 4th gen F fans with a G radiator......Combination of (UNGN), 300M fans, (fleming442), 3rd GEN Camaro/4th GEN rad. The 300M fans fit perfectly between the tanks. Putting this combo in my 85SS. If needed may step up to a Champion 3rd GEN rad. Also going to run a Volvo fan controller for easier wiring. (2 speed)
