Radiator help how many cores?
78Delta88
1,250
1,015
SW Arizona
I'm thinking you can find an original brass radiator somewhere in America however, It will pose to be quite difficult due to aluminum radiators have all but replaced brass ones AND all the old guys who had radiator shops back in the day when brass ones were the norm are either out of business or dead. There must be places for radiators like Cooker tire who specialize in old style tires for radiators.
Yep. On your radiator you might have to go with aluminum and plastic tanks to keep car running. Wash it out with diesel or B12, stop any future corrosion. Pack what you have real good in mean time until you can find replacement . The cores are around, but the side tanks will be very very difficult to find.
On the tank you will see the solder line. Back when I started we used a shop in Downers Grove, owner was a very nice older black fellow..., always had beers and stories. Told me he started back in depression days when he was a kid.
Process is simple... Heat the radiator and solder melts, tanks come off. He stocked all the common size cores, plus he made custom when needed. Once you get the tanks off clean up make sure tank thickness is still good, resolder to the new core. Pressure to 15psi in a water tank, check for bubbles and when good, clean, dry and paint.
pagrunt
9,124
15,255
Elderton, Pa
Summit advertised brass/copper radiators, not sure if they carry ones for a base V6.
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
Why do you want a brass,copper radiator?
565bbchevy
9,590
12,612
Michigan
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
CrammerGram69
430
140
SW, Michigan
Good thought & Idea. i will look into it.
CrammerGram69
430
140
SW, Michigan
Yep. I looked on there but out of budget price range. I'm kinda at $150 max.
CrammerGram69
430
140
SW, Michigan
it's pretty much an all original car, i don't wanna ruin with it Aluminum just because it's rEaDiLY available. lol. hardcore GM Purist here.
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
Ruin is a tough word. But I do understand ‘original’ .
Find a radiator repair shop to either repair or replace the core. Money will solve all issues (no kidding)
CrammerGram69
430
140
SW, Michigan
Gonna try that. If not ask around for me. I need some good used ones for core.
