Radiator lower bushings
For the win!
I don't know if the glue will hold up with the heat but I wanted to hold the rubber in place while I install the rad. It's not going to move with the rad sitting on it and if I have to reglue it again if I remove the rad is easy enough
Reactions: Tony1968
200 or so degrees isn't too hot and gorilla glue is pretty strong. I'll do the research on temp limits for various glue substrates.
We happen to sell these now if the Gorilla Glue method doesn't pan out for you.
Reactions: Tony1968
