firstly, where did you guys get the 45* brass fitting so the oil sending unit will fit? I tried 2 90*'s but not enough clearance.
secondly, i have 2 lights out... L turn signal, and the tach seems real dark. i swapped bulbs, but they still dont work... could something be wrong or should i just check the contact points and get new bulbs.
i was trying to mess with the odometer of the new cluster to match my old one. i was dicking around for like at least a half an hour, then realized i could just swap them. that took up the most time out of the swap
lastly and most importantly, my gas gauge reads way over full, and its only like 3/4 full. i don't need a different sending unit in the tank do I? the one i have in there is only like 1-2 years old...
