It was not a problem it was a slow progress. Initially not every thing work had to pull and clean tighten reassemble several times.
If I had to do all over again I
would get the LED bulbs right from start .I had to make a couple trips to the parts store.
Follow the directions and all is good.the temp sensor listed is no longer available. I asked for a 87 442 single wire sensor and then needed to purchase an adapter.
Overall it was straight forward installation.
I did run an extra wire for the idiot light to also work
Thanks for the kudos.... looks like it’s going to come out one more time ,accidentally bumped the blinker toggle while cleaning and noticed the cluster not blinking but the lights outside are. It worked a couple of days ago
Don't feel bad I had mine out 4 or 5 times until it all worked. I have a 3.8 L V-6 car and installing the one wire sender for the oil pressure was a trip. Adapters and pipe nipples and such, Good luick and keep us up on your project.
