rally gauge conversion
Lol. I hear ya! The cluster is back in and everything is working except for the left blinker staying lit with the lights on. All wireing is correct .
Need to check the blinker bulb. Up front. Looks a little dim.
I ordered a new circuit board but might not need it afteral. The L E D lights where needed. The reg bulbs where way dim
Question: Does this "fix" require changing the old printed circuit on the back of the instrument cluster? As mentioned earlier, these printed circuits are so old and flimsy they are basically huge "frustration time-bombs." Has anyone tried wiring directly to the clamp connectors for each gauge or rewiring the cluster?
If the bulbs are dim, start checking the grounds and the contacts in the sockets; they're usually the first to corrode. I've mentioned this before, but I'll say it again. Near the horn, on the driver's fender, there is a ground splice that puts 6 18ga. grounds to one 18ga. for the front lights. Cut that off, and replace it with a 10 or 12ga. and ring terminal to ensure proper current flow.
