I Have A Question I Have Two Rear ends Both Out Of A Cutlass 81-87 Need To No Witch One Is Better And If The Gearz Have Been Changed. Hoping Its A Posi But I Know Nothing About them Looked Up The I.D Stamp On Them Both Are 7.5 and 1 the gear ratio is 2.41 and the other is 2.29 I Took The Cap Of The 2.41 Looks Like A Swap As U can See In The Pic The Bolts Inside Have A L On Them I Am Guessing That Is For Limited Slip Either Way I Want Posi And I Plan On Putting A Crate 350 Sb Chevy That Put"s Out 425Hrsp At The Most So Wat Are My Options I Was Thinking 3.73 gears or 4.10 Car Will Never See A Track Just Street Car Plus I Was Thinking Trying To Find A 8.5 Witch Prob Wont Happen Or Ordering A 9" Ford From Summit Also Read On Here I Could Swap From A 68 to 72 A Body Gm 12 Bolt Witch I Prob Wont Be Able To Find That 1 Either I Don"t Want To Spend Alot That"s Why I Was Hope I Could Just Beef Up The 7.5 The Body Is Off Frame So Changing Is Not A Prob Any Help Would Be Appreciated Thanks Oh And Adventually Plan On Changing To Disc Brakes If That Makes A Difference In The Decision Again Thanks
