rear axle help please
Just slip the spring over that it and use it as it is
Wow, Monte SS 3:73 posi's go for 400 to 500 around here if you can find one,
timo22
You can find 3.73 posi SS rears all day for about 250 bucks, thats probably your best bet.
Im gonna assume with that much wire on the perch he tweaked the tube putting that much heat in it.
Rear end by you on Craigslist for $25.00
© craigslist - Map data © OpenStreetMap
8320 NW 38th Ct.
(google map)
condition: good
make / manufacturer: Chevy/ Ford
QR Code Link to This Post
Stock rear end from a V6 gbody chevy in good condition. Changed out for a geared posi rear end $25. Aluminum Radiator from 04 Mach1 mustang $30. Brand new dual fans with shroud $75.
  • do NOT contact me with unsolicited services or offers
post id: 6363401906
I figured it was a 7.5" 10 bolt rear by it's spindly looks. The cover and bottom "fangs" comfirm it. As said find another rear, 3.73 is steep with a 3 spd trans on the highway.
We’re are there 373 rears for 250 ???
