Rear Cover Help
Hickrocket1258
105
24
West Chester, PA
Ok so I have a feeling I know the answer, but I figured I'd ask anyways just to make sure. With the rear on the right which I picked up, there is no hole on the cover to fill the rear end. Is it just a simple cover change? Right now I'm not sure how much gear oil is in there.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
there is a fill plug on the right side near the axle tube on the front side. Remove the plug to check the oil level. It should be at the top of the bottom of the fill hole
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
To take out the filler plug I use an old 6" 3/8" extension, first I clean the dirt out of the plug, I put the male side of the extension in and then I take my mallet and hit the extension with a few good shots. That seats the extension and usually loosens up the plug so you can remove it. If that doesn't work a little heat will help. When I put the plug back in I butter the threads with anti seize.
