Rear Defrost
SupremeSpeed
596
802
GA
I recently notice the rear defrost in my 88 Olds Cutlass stopped working. A few weeks later my interior dome light stopped also. Any suggestions would be greatly appreciated. I sure hope it's not a bad wire harness.
Check your fuses first. If that checks out check all connections to ensure they are tight. If that checks out follow the power wire from the fuse block back with a test light and see where the power stops.
Thanks for the helpful tips. I will get right to that.
