Email either Ed Miller at
www.flynbye.com or Tobin at
www.kore3.com Both are regulars on pro-touring.com among other boards. Either one or both can guide you to what you need. Ed modified my prop valve to work with disc/disc setup. The mod is supposed to be fairly simple needing to remove a valve internally. Disc and drum brakes require differant pressures and this valve regulates them. Without this valve, the front and rear disc get the same pressures. But just because this is a g-body prop valve, when you swap from drum to disc you are also changine the sizes on the front andrear brakes. That's why it's still recommended to run an adjustable rear valve. You can run either a modified prop valve *and* an adjustable or just the adjustable in solo. That way you can still have full pressure to the front and adjust the rear down to just below lockup simce the front does most of the braking and is usually larger in diameter.
If I'm not mistaken, even Baer uses the stock master. That's what Ed recommended I use but since I haven't got my setup installed I can only pass on his advice to me along to you. Or, you can email him on your particular setup as it may be differant than mine. I'll be running the 13" C5 front and the 12" LS1 rears...eventually...
