FE3X CLONE said:If you've never changed gears then I wouldn't attempt it on a daily driver/sole transporation type car.
The GN rear would be an 8.5" with 3.42 gears. A 442 or '84 H/O rear would also be an 8.5" with 3.73 gears. Personally I would rather have the 442 or H/O rear for the steeper gear ratio. However really both would be overkill for a pretty mild 350.
The Monte SS rear axle wouldn't be much of an upgrade beyond the better gear ratio. They still only had the 7.5"/7.625" rear.
If you do go with an 8.5" you will need to shorten your driveshaft by .99".
What gear ratio do you have in the Cutlass now?
I tried finding the axle code but I don't see anything and I don't know exactly where to look, im looking at the passenger side but don't see anything but its kinda dirty too so that may explain why I don't see anything lol
