Rear frame measurements needed.
6togo
Apr 25, 2013
95
16
Does any one know or can measure the rear bumper shock mounting holes center to center. Prefer one that is mounted to the body so its held straight mine is off some and before i make a brace i want to get the rear rails fairly close i think i came up with around 52" from the lower dr. center bolt to the pass. lower inside bolt hole.
give me year and make and I will see if I have the measurements. I own a frame body shop and have most frame sects on hand and can email you them
Good question, I would be curious to see this as well. I have see frame specs posted before, just not sure if this was one of the measurements.
still looking as they are not in my normal frame specs cd.i will have to dig up my old books to see if there in there or I even go back to 86
if a drawing that gives you all the measuremtn of the frames including the measurment of the rear rail to rail doesn't help you then good luck
I tried to use those before and they did not work at all with the GN frame when i had it on the ground out of the car! I'm not asking for anything difficult anyone with a assm. G body has what i need just a matter of a good samaritan measuring it for me! :wink:
