Thats the spirit, if you can weld and have the time then rust is largely irrelevant.Ill have it repaired by end of this weekend hopefully. Been busy. I have the metal on hand. It's 12 gauge by the way.
Thanks. How about the bolt? I was gonna just use a nut and bolt and two large washers ..The one with the metal insert will be on top with the body resting directly on the metal insert.
They are normally a cage nut set in a pocket of the body under the floor sheet steel. I think there is a tech thread on it here. You can nut and bolt it like your thinking but not sure if it will leave the body move to much because of the gap of that space. One of the other guys may know better then me.Thanks. How about the bolt? I was gonna just use a nut and bolt and two large washers ..
Sounds like a…. fun welders challenge haha.Sadly this was the reason why i had to do a complete part out on my pretty rare 1978 Pontiac 2dr Grand LeMans Landau coupe 🙁 Even had the console and bucket seats in the 1 yr only white interior. RFR where gone. No meat left anywhere. needed extensive body work as well.
My theory, GM trying to make the cars smaller & lighter for better fuel economy they tried to go with a lighter steel than the three generations before. It wasn't just with the frames as we all know. On top of that I'm believing our generations was originally drawn a bit bigger but was scaled down which also added to thse rot as the original design could of prevented those areas prone to rotting from holding what materials being water, salt, dirt, etc... I would say if our cars were like the third gen A's, something like how the first & second gen A are like, we might not have as much of the rot we have had. So in the end, GM fudged up everything so I'll place it as their fault. Enviromental conditions didn't help & was most likely helped by GM's final design.With so many others contributing what they did to address this kind of extensive frame rot, I'm curious as to what was/is the major cause? GM's design flaws? Environment, i.e., salt on roads?
