Rear Seat Support Brace
tngbody
104
20
Is it possible to replace this without removing the body from the frame completely?
5,711
12,223
Exactly what are you describing/asking about?
tngbody
104
20
The rear seat floor brace that spans left and right in the rear. Is it possible to replace it without removing the body from the frame.
Rktpwrd
Builder of Cool Shjt
4,173
23,929
Calgary, Alberta, Canada
No, as it houses 2 of the body mounts. One on each side. At the minimum you’re looking at removing the body mount bolts and jacking the body up off the mounts to have enough clearance to remove it.
Begs the question, why do you want to remove it?
tngbody
104
20
It is rusted pretty good.
abbey castro
1,049
1,318
Harker Hts TX
is it the one on the inside or underside? if it is the underside one, yup th ebody has to come off since as stated before; body mounts pass are there
tngbody
104
20
It's the outside one.
